4WD issues
Old Sep 16, 2008 | 01:23 PM
jukdd's Avatar
jukdd is an unknown quantity at this point
Default 4WD issues
So, my 4 wheel drive will not engage while in drive. But 4WD Low will engage when in nuetral, but HIGH won't. It was fine in the winter when 4WD high would turn on while in drive. Suggestions?
Old Oct 20, 2008 | 09:00 AM
theonlytick44's Avatar
theonlytick44 is an unknown quantity at this point
Default RE: 4WD issues
Mine just started doing the same thing yesterday. have you gotten any suggestions yet?
Old Oct 20, 2008 | 11:22 AM
raylo's Avatar
raylo is an unknown quantity at this point
Good chance it is the transfer case encoder motor. When they start to fail you get intermittent problems shifting into/out of 4wd. Sometimes you candisconnect the battery and when you reconnect it the transfer case will shift where you want it to. New encoder motor is not a hard or super expensive fix.
Old Oct 20, 2008 | 04:38 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Check the link in my signature. I would test your 4Lo in wet grass or mud to see if it is really engaging in 4WD or if you are just hearing it try to engage.
You probably have the same problem I did with your vacuum actuator not working. These trucks are know for this problem.
Old Oct 21, 2008 | 07:56 AM
chevygulr84's Avatar
chevygulr84 is an unknown quantity at this point
your not supposed to engage your 4 wheel drive while moving, only in park or neutral soit probably messed up your transfer case. Not a cheap fix.
Old Oct 21, 2008 | 07:48 PM
mysons95's Avatar
Nah, you can go into 4x4 hi on the move in drive. It`s when you go from Hi to Lo that you need to go into neutral.
Old Oct 21, 2008 | 08:21 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
OMG [sm=massbounce.gif]that POSI-LOK how to link has me going crazy! I can't wait to try it.
Old Oct 22, 2008 | 05:15 AM
mysons95's Avatar
I realize it is not the cure-all for all that ails you or your truck, but it sure fixed me and mine up in a hurry. I hope it helps you.
Old Oct 23, 2008 | 02:59 PM
Hanr3's Avatar
Hmmmm, I wonder where they go the idea to replace the posi lok like that?
Maybe from me.
Old Oct 24, 2008 | 05:17 AM
mysons95's Avatar
ORIGINAL: Hanr3
Maybe from me.
No doubt...you and many others that I read on this site.
Check my page on the posi-locking system. You are the only one I sited because you had a how-to on it.
But I had a hard time following it, so I started over and decided to write my own with more steps and more pictures.
