4WD problem
Old Jan 30, 2011 | 11:20 AM
BugOut's Avatar
BugOut is on a distinguished road
Default 4WD problem
2004 Blazer.
When in drive, none of the 4wd buttons light up when pressed.
When in neutral, I can get the 4lo to work. When the 4hi button is pressed, everything flashes and it goes back to 2hi.
I can hear something being switched in the passengers side floor when I press 4hi, but 4hi never actually engages.
And sometimes if I press 4lo, it will engage and work, but none of the buttons are lit.
Any suggestions on where to start?
Old Jan 31, 2011 | 08:05 PM
BugOut's Avatar
I ran a scan today. No codes came up.
Any ideas?
Old Feb 1, 2011 | 01:38 AM
UberFail's Avatar
UberFail is on a distinguished road
go to the tech section and check out the DIY 4wd no worky (or something like that) thread. in there u can find out how to diag the 4x4 but iirc the encoder motor might be crapping out as it goes from one extremedy to the other (misses 4hi). hope that helps!
Old Feb 13, 2011 | 11:37 AM
YAXTA'S04BLAZA's Avatar
YAXTA'S04BLAZA is on a distinguished road
I have an 04 with the SAME exact problem right now..did you ever figure out what the problem was?
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
waterskier98
Mar 4, 2009 03:15 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
