4wd Problems... need help / part numbers
Old Mar 27, 2010 | 03:43 PM
DMalloy9782's Avatar
DMalloy9782 is on a distinguished road
Default 4wd Problems... need help / part numbers
Hello there,
I have an '02 BLazer s10 LS with a four button auto 4wd transfer case, and my 4wd is not functioning. Whenever I press a button to engage 4wd, the lights in the switch just blink continually. I took it to a family mechanic, and he said my encoder motor was shot and referred me to a transmission shop. They tested my truck, and said my encoder motor was fine, and I needed a new TCCM (model 15748800). I replaced the TCCM (with model 12577412), and this did not repair the issue. Can someone please tell me what model transfer case I have, what encoder motor would work with that, and if there is anything else in this chain I should be looking at? All related fuses have been checked, and replaced just for safety even though they were fine. I don't have a reader, but when we checked the obdii codes, it was flashing 5 or 6 of them, something about shift solenoids a and b, and something else relating to "TCC" which I assume meant the TCCM?
Old Mar 27, 2010 | 04:40 PM
How many buttons do you have on your 4wd switch?
What were the specific OBD2 codes that you pulled (Pxxxx)?
Old Mar 27, 2010 | 04:44 PM
SureShooter29's Avatar
SureShooter29 is on a distinguished road
He stated he had the 4 button 4wd switch in the first line. NV236 transfer case correct?
Old Mar 27, 2010 | 05:20 PM
Yes, I missed that. Was reading it too quickly.
You need to pull the codes with a scan tool capable of communicating with the TCCM.
Old Mar 28, 2010 | 08:44 AM
I don't have a reader, but off the top of my head using a chart, it was Shift Solenoid A electrical (P0753), Shift Solenoid B electrical (P0758), TCC Enable Solenoid circuit electrical (P0740), and two more I can't recall. At the time this was scanned though, I couldn't get my truck to start or the keys to come out of it either, it was right after I replaced the heater core
v8 jago
Dec 1, 2011 05:21 PM
spider21
Nov 17, 2011 06:27 PM
Tortex53
Mar 12, 2011 12:51 PM
LAJ11
Oct 31, 2006 09:16 AM
nerve_agent
Oct 20, 2004 04:21 AM
