4WD question?
Old Jan 1, 2015 | 09:19 PM
Possum 6991's Avatar
Possum 6991 is on a distinguished road
I replaced them one at a time so I don't think that they are in the wrong location on the vacuum switch. It does pull the actuator some when 4wd is engaged so I believe that the lines are on the correct ports. It does also release the actuator when 2wd is selected.
Old Jan 1, 2015 | 09:56 PM
What's to say the lines were on correctly when you replaced them? Check the routing in the first image. Make sure the vent line routing is correct. If the filter is connected to the actuator circuit, the actuator will not get full vacuum. Something is obviously wrong. Should show manifold vacuum in 4WD at the actuator with the engine at idle.
Old Jan 1, 2015 | 10:08 PM
I gotcha. If I replaced them and I put them back to the way they were they could have been wrong to start with. I'll double check them. On the vacuum lines up by the fender there is a line that goes to inside the cab for HVAC. Is it a real small hard line (about 1/8" diameter)?
Old Jan 2, 2015 | 09:40 AM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Is your front diff low on 80w-90?
Old Jan 2, 2015 | 01:01 PM
Possum, you are correct on all counts.
On the left inner fender, the black rubber vacuum line changes to hard black plastic, (about 1/8" diameter). Pull the rubber line off and connect the vacuum pump directly to the plastic line. After checking for leaks on a particular mode, when you switch to the next mode position, the vacuum might deteriorate, (normal) and you'll need to bring it back up to ~18". Make sure each mode position test starts with ~18" of vacuum.
Old Jan 3, 2015 | 09:55 PM
I applied vacuum to the line going to the actuator (from the t-case end of line) and it engages (by hand turning the wheel it rotates the drive shaft) at as low as 5" vacuum. The plug has 2 - 5/32" lines (1 for actuator and the other is for vacuum supply). The other line is 7/32". It was connected to the vent.
I have another vacuum switch here so I put the plug on the switch and applied vacuum to some lines that were only 6” long. I could not get the 7/32” to hold a vacuum with the ball in any position (vent line). I could get the 2 – 5/32” lines to hold vacuum together by pushing in on the ball of the vacuum switch (4 wd mode). The supply side would hold a vacuum with the ball in or out. The actuator line would only hold with the ball pushed in (with the ball not pushed in you can blow into the actuator line and it comes out the vent line (7/32”) (2 wd mode).
The 2 – 5/32” lines were reversed. I finally have 4wd.
Old Jan 3, 2015 | 10:07 PM
Good, glad you figured it out. Thanks for posting back.
Old Jan 4, 2015 | 12:16 PM
Blazin00LT's Avatar
Glad to hear.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
