4x4 issues (vacuum line)
Old Aug 18, 2010 | 01:26 AM
Flyboy024's Avatar
Flyboy024 is on a distinguished road
I would check the voltage on the buttons. Mine did the same thing and it turned out to be the buttons. Sometimes the button switch can do weird things.
So the electornics in the system work like this. The TCCM receives signals from the buttons, front axle sensor, ParkReverseDrive switch, Speed sensor, and a sensor on the encoder motor. Those are the only things that affect your what your buttons tell you is going on. Vac won't cause that problem.
Old Aug 23, 2010 | 03:58 PM
Christobal's Avatar
Christobal is on a distinguished road
Hi guys. I have the same problem on my 1992 blazer.
Where do I have to take a look(?!)
Is there a way to put manual locking hubs and manual actuator for the front drive?
thanks a lot
Old Aug 23, 2010 | 04:06 PM
If you have the NP233 electric shift transfer case, search for "NV233" and see what comes up. This thread is about the NV236 which was not available in the 1st gens.
About manual locking hubs, no dice. There is no way to use manual locking hubs given the way the s-series hubs are configured. You would have to do a LOT of redesigning of the hubs, etc to get disconnects at the wheels like the solid axle folks have.
Cassera
Jul 14, 2012 03:46 PM
Shelly10589
Dec 17, 2011 09:20 AM
Johnny Glenn
Feb 19, 2011 10:20 PM
Kerias
Engine & Internal
Feb 28, 2010 08:19 PM
rsheltro
Dec 26, 2008 09:11 PM
