4x4 Not engaging?
Old Jan 24, 2013 | 04:05 PM
matt9589's Avatar
matt9589 is on a distinguished road
took a video today. I took out the battery, and tray, then connected the battery to juper cables to see if the vacuum actuator works. It doesn't even move........will post video after it uploads
Old Jan 24, 2013 | 04:08 PM
matt9589's Avatar
Heres the video
Old Jan 24, 2013 | 06:38 PM
Engine must be at idle, transmission in park, and then select 4WD.
Old Jan 24, 2013 | 06:56 PM
matt9589's Avatar
will do that tomorrow with video. I shouldve had the car on lol
Old Jan 24, 2013 | 06:58 PM
Yup, need electrical for the encoder motor to work, need vacuum for the actuator to work.
Old Jan 24, 2013 | 07:01 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
or going less then 3mph can shift in neutral too.
Old Feb 22, 2013 | 04:24 PM
matt9589's Avatar
bought and installed a new vacuum actuator thinking it was the problem and it wasn't.....did your test captain and i am able to move the tire by hand still.....now what?
Old Feb 22, 2013 | 09:15 PM
Banned
tcase chain broken?
Old Feb 24, 2013 | 08:36 PM
LF tire on the ground, if you can rotate the RF tire with the cable manually pulled in, (about 3/4"), the problem is in the right front axle tube. Check the cable connection at the axle tube. If the cable is connected, the axle tube will need to be removed and disassembled to diagnose the problem.
seriosbrad
Nov 7, 2015 09:08 PM
chrisblaze
Dec 6, 2009 12:27 AM
TheBrettster
Mar 31, 2007 07:24 AM
Jared
Sep 15, 2006 12:52 AM
I8URVTEC
Jul 28, 2005 06:56 PM
