4x4 problem
Old Dec 26, 2025 | 11:52 AM
Jmack's Avatar
Jmack is on a distinguished road
Default 4x4 problem
1998 Chevy Blazer 4wd 4 door
I accidentally pushed the 4 wd low button while I was driving. The 2 wd light is on now. When I push 4 wd button the light flashes then the 2wd light is on. Anyone know how to fix this?
Thank you
Old Dec 26, 2025 | 03:37 PM
int3414's Avatar
int3414 will become famous soon enough
i would wonder if you hear the shift motor moving?,,,i would guess not....i have banged on the shift motor with a hammer,,my problem solved...that was last winter...still working
Old Dec 26, 2025 | 08:13 PM
braden737's Avatar
int3414 is most likely correct that your shift motor has an issue. I just wanted to add that you pressing 4 lo on accident cannot cause any additional damage because your computer requires the car it be in neutral to shift into 4lo.
Old Dec 27, 2025 | 10:20 AM
Jmack's Avatar
I put it in neutral, pressed the brake, pressed 4 low button. Now it’s stuck in 4 high.
Blazer008
Dec 23, 2012 08:07 PM
James Honey
Nov 11, 2012 11:11 AM
lityjohn701
Sep 28, 2012 10:21 AM
99blazer2dr
Mar 6, 2012 07:13 PM
Chevy33
Mar 27, 2011 10:42 AM
