4x4 problem actuator always has vacuum on it even in 2hi
Old Apr 14, 2021 | 06:48 PM
Cchey91's Avatar
Cchey91 is on a distinguished road
Default 4x4 problem actuator always has vacuum on it even in 2hi
My 95 blazers front axel vacuum accuator has vacuum on it even when its not in 4hi on the 3 button switch is that normal im afraid that my front axel is engaged even in 2hi
Old Apr 14, 2021 | 07:52 PM
This one sentence, doesn't really make sense. Can you elaborate a little more please?
Old Apr 14, 2021 | 08:08 PM
Cchey91's Avatar
Ok i start my blazer and its in 2hi right according to the 3 button switch. Now while started i remove the battery and tray to see the actuator for front axle. The actuator is pulled in (engaged) all while still in 2hi. The vacuum never goes away on the actuator no matter what button i push on the 3 button switch
Old Apr 14, 2021 | 08:23 PM
Did you have the vehicle off the ground to see if the wheels are actually engaged? Or just by the actuator? These tend to go faulty, and a lot of people go with a bravada swap or make it a manual shift setup.
Old Apr 14, 2021 | 08:33 PM
Cchey91's Avatar
No i did not have it jacked up but ill try that tomorrow and see if they are locked in or not i was just curious to if the Tc vacuum switch could be stuck open and allowing the engines vacuum to stay on the actuator instead of having it vent
Old Apr 15, 2021 | 06:54 AM
I'm not sure myself, just trying to get more info for other who know more.
Wonder if your actuator is stuck and not the vacuum.
Old Apr 15, 2021 | 09:26 AM
Cchey91's Avatar
No the actuator releases when i turn off the engine
Old Apr 15, 2021 | 11:56 AM
Sounds like either a bad vacuum switch, or you have the hoses hooked up wrong.
Old Apr 15, 2021 | 05:41 PM
Cchey91's Avatar
I figured it out thank you guys it was the vacuum switch stuck on so i replaced it and works perfect.
Kknd310
Aug 5, 2015 10:35 PM
blz_22_75
Feb 25, 2013 09:41 PM
kevinph
Dec 20, 2010 04:58 PM
deegan26
Dec 15, 2009 12:47 PM
carlo
Aug 1, 2007 11:01 AM
