4X4 problems
Old Sep 30, 2007 | 01:47 PM
higinio3's Avatar
higinio3 is an unknown quantity at this point
Default 4X4 problems
My 02 4X4 will not shift into 4WD, when I push any of the 4X4 buttons the light just keeps flashing, any ideas?
Old Sep 30, 2007 | 03:00 PM
99 Blazer 4x4's Avatar
99 Blazer 4x4 is an unknown quantity at this point
Default RE: 4X4 problems
When you push the buttons do you hear anything try it on your driveway with the door open. See if you hear anything like the shift motor on the transfercase if not could be electrical or could be in the transfer case itself.
Old Sep 30, 2007 | 05:39 PM
hillbillyinOhio's Avatar
first check your fuse panel. many times the fuse will blow!
Old Oct 3, 2007 | 06:54 AM
jcoop711's Avatar
jcoop711 is an unknown quantity at this point
I had this problem a few months ago and took my 2000 blazer to the dealer. They sais the encoder motor was bad and it would be around $900 to replace it. I declined to have them replace it. I wanted to find out if it was something I could replace myself. When I picked my blazer up from the dealership they had to jumpstart it because someone ran the battery down.
On the way home out of frustration I pushed the 4 hi button and it shiftedwith no problems.
To this day it still works,I think the battery going dead reset the codes in the computer.Try unhooking your batteryfor a few minutes and maby this will do the same for you. I know it saved mealot of money. Good Luck.
Old Dec 11, 2007 | 02:54 PM
aspenrebel's Avatar
aspenrebel is an unknown quantity at this point
that's an idea.. disconnecting the battery
Old Dec 13, 2007 | 07:14 PM
lad446's Avatar
lad446 is an unknown quantity at this point
I have a 95 Chevy Blazer LS and of late it has been doing some really wierd stuff. About a month ago it started making a wierd noise that made it sound more like a motorcycle than a car. The noise gets louder when I slow down. I was on my way to Aamco to check it out and then it stopped. They checked my transfer case and said it was fine.
Two days ago, when starting my car, my navigation system (I have a Pioneer AVIC D3) did not load. I turned the engine on and off twice but the same problem. The colors on the side of the system kept changing which means it was getting power, but it did not load. I drove all the way home, pulled into the garage, turned off the engine and on a whim thought lets turn the car on again. This time, the AVIC D3 loaded!
Yesterday I was on the freeway and all of a sudden I thought the engine was a little loud...I take great care of this car and the engine is very quiet and she usually purrs like a kitten. Being that I was on the highway and travelling at a pretty steady rate, I had no way to gage that the same problem had returned until I slowed down and I heard the "motorcycle-like" noise.
This morning I was trying to figure out what had gone wrong again and I started playing around with the 4x4 buttons on the dash. If I hit 4-hi the noise stops but every now and again, I feel a thumping from under the car. However I can feel that the front wheel have NOT ENGAGED. When I switch back to 2-hi, the noise starts again. If I am sitting in N or completely parked and try to engage the 4-lo, it will not even engage at all (the light doesn't flash - nothing) in fact it throws me back to 2-hi!
Is this an electrical thing or something with the transfer case or the vacumm???!!!
Old Dec 13, 2007 | 09:31 PM
Again lad, try to keep this in one place, the initial thread you started. No need to spread the exact same post around over multiple threads and sections.
notrealimportant
Jul 15, 2011 01:29 PM
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
chevblazer02
Oct 15, 2006 03:03 PM
vtlew
Jun 23, 2006 09:13 PM
