#5 cyl full of gas
Old Jan 3, 2013 | 03:07 PM
cannon's Avatar
cannon is on a distinguished road
Default #5 cyl full of gas
Im back with another problem. 95 blazer stalled and wouldent start. Checked battery and starter both ok seemed like motor was locked up. Pulled plugs and about a cup of gas came out of #5 cyl. Motor cranks fine now but keep getting gas from #5. No gas in oil. CMFI shot??? any help will be appreciated
Old Jan 3, 2013 | 03:24 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
leave plug out, get that cyl towards tdc and turn ignition to on. see if fuel come pouring out from the fuel pressure out the spark plug hole
Old Jan 3, 2013 | 03:58 PM
cannon's Avatar
it does
Old Jan 3, 2013 | 03:59 PM
Banned
leaking injector.. replace it. probably poppet style stuck open.
Old Jan 3, 2013 | 04:05 PM
A leaking injector would fill all of the cylinders on the CPI engine given the configuration of the spider. This is likely caused by a failed fuel pressure regulator. To replace it, you have to pull the spider which means disturbing the "nut kit" (internal fuel lines) which must be replaced unless you want to be back in there again in short order.
There is a how-to in the tech article section on this repair.
Old Jan 3, 2013 | 04:14 PM
Banned
my bad was thinking it was the other vortec
Old Jan 3, 2013 | 04:22 PM
cannon's Avatar
So i should replace the nut kit and regulator?
Old Jan 24, 2013 | 06:09 PM
cannon's Avatar
Problem was the nut kit pressure line was leaking. Not too bad of a job. truck runs good now. thanks for the replys.
goerzenl
Nov 1, 2010 10:14 PM
mattlinke
Jan 21, 2010 10:04 AM
vaportrail
38
Sep 21, 2009 05:38 PM
midnightbluS10
Sep 3, 2009 03:24 PM
PhatKat
Mar 30, 2006 07:13 PM
