700r4 from 4x2 into a 4x4?
Old Jul 12, 2011 | 05:18 AM
maepis's Avatar
maepis is on a distinguished road
Question 700r4 from 4x2 into a 4x4?
I have an 86 fullsize Blazer with a 305 and a 700r4 tranny. The tranny won't shift out of first gear so I need to do a rebuild on it but I found an ad on Craigslist for a 700r4 from a 4x2 truck for only a couple hundred bucks. If I bought it, would I be able to put it in my Blazer or would I just be throwing money away that I should save for a rebuild? I've been told by some people that it will go in there just fine and others say that I'd have to do some kind of modifying to it. I don't know what the right answer is. I'm a total newb to the transmission game so any help and guidance would be greatly appreciated. Thank you.
Old Jul 12, 2011 | 07:01 AM
Common question.
The answer is yes. However, the tail shaft needs to be swapped out for the 4wd specific tail shaft. To do so, the entire transmission must be gutted. The tail shaft comes out the front of the transmission.
Old Jul 12, 2011 | 03:53 PM
TheRandom1's Avatar
What he said. And by doing that you're basically rebuilding the trans anyways... so it makes more sense to save your money and rebuild what you have.
Old Jul 12, 2011 | 05:39 PM
abig84's Avatar
its possible to get lucky but doubt it. if it was one of those things you had both sitting next to each other you could see if the tailshafts are identical or not.
Old Jul 12, 2011 | 05:46 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Unless you pick up a 2WD driveshaft and remove transfer case and front driveshaft so you can run without 4WD until you get yours rebuilt. That's the only way it would be worth it without doing a lot of unecessary work.
bigdaddykane93
Jan 27, 2016 11:35 PM
lilflippa88
May 30, 2010 07:05 PM
Rusted Dream
Sep 30, 2008 01:50 AM
cyukio
Lifting Tech
Aug 22, 2007 04:15 AM
76BadSign442
Feb 1, 2007 11:12 PM
