700r4 accumulator bore..
Old Mar 27, 2010 | 07:13 PM
Dakota_Don's Avatar
Dakota_Don is an unknown quantity at this point
Default 700r4 accumulator bore..bock it off
Hello upon tear-down of my 89 700r4 i found the 3-4 accumulator was scared up.
is there a fix for this? if there is what is it? can i block it off??
thanks
Don
Old Mar 27, 2010 | 07:42 PM
If 3-4 accumulator bore in case is scored up, salvage it by installing a Sonnax sleeve kit P/N 77998-01K.
Old Mar 28, 2010 | 08:40 PM
Dakota_Don's Avatar
kool thanks, I found it and ordered it..
Old Mar 30, 2010 | 07:35 PM
Dakota_Don's Avatar
hello. i called trans=go since i am using thier kit, they said i could block off the 3=4 acc piston, they said i could use two pistons and seal and just block it off using them.. what do you trans builders do?? block it or sleeve it. i would like to firm up the shift, but not break anything..
GM Nut
Mar 8, 2015 12:47 AM
ScottieHargrove
Dec 31, 2011 01:52 PM
airmaxx28
May 30, 2010 06:45 AM
Dakota_Don
Apr 6, 2010 11:28 PM
greenjimmy
Engine & Internal
Mar 18, 2009 11:05 AM
