700r4 load and release and forward sprag rotation
Old Mar 29, 2010 | 04:57 PM
Dakota_Don's Avatar
Dakota_Don is an unknown quantity at this point
Default 700r4 load and release and forward sprag rotation
Hello. i have a GM swappers manual, and it says I can (and most rebuilders) leave out the load and release springs (cushin springs) as long as i drill the proper holes in the vb plate? is this true? i have heard if i did this the cluch pack will hit hard, and may not release?
also if I hold the forward (overdrive) sprag with the large part in my hand, and looking at the smaller part of the sprag it should rotate ccw, and if i hold the small part and rotate the large then it will rotate cw? stupid me took it apart cleaned it, and laid it down and got called away.. you know the rest.. duh...... which why did it go??
thanks
Don
Old Mar 29, 2010 | 07:30 PM
The removal of the 3-4 load release springs depends on whether you are increasing the 3-4 clutch count. If you are staying with 6 clutches, you do not want to remove the springs. If you are going to 7, 8, or 9 clutches, then you cannot use the stock springs and would have to go with an aftermarket spring kit (like THIS).
I believe that the outer race (larger side) of the forward sprag goes towards the back of the transmission.
Old Mar 30, 2010 | 02:55 PM
Dakota_Don's Avatar
hello, thanks for the info, but i was wanting to know what direction the spag turns? if i hold the large end in my hand while looking at the smaller end, i think it turns cw..
thanks
Old Mar 30, 2010 | 03:16 PM
That, I am not sure of... It's been awhile.
edphot2009
Tires and Wheels
Apr 21, 2011 01:01 PM
Kirk-NJ
Feb 24, 2010 03:25 AM
blZrRooK
Aug 27, 2009 02:22 AM
S10Blazer
Sep 1, 2008 08:41 PM
raviz
Nov 21, 2006 09:54 AM
