4 wheel drive stop working
1996 s10 blazer 4.3 push button 4wheel drive. First the 4 low stoped working changed the actuator and transfer case motor. Nothing changed. Then the 4 hi stoped working. changed the vaccume switch on transfer case. Did not change nothing. I was wondering where the lines from the vaccum swith suspost to go to. They look like they were cut. There is one running to the acutuator one is goin to the vaccume canister on the hood. one is hooked into a spliter and the line from the trasfer case i guess it is a vent is in it to. the spliter is a 2 to 1 2lines go in and one go out and nothing is hooked into it. the 4 high light comes on but dosent engage 4low blinks and goes out
If the transfer case itself will not engage, then the problem is likely with the encoder motor or the TCCM. What does it do when you try to change to 4HI or 4LO? Have you pulled the TCCM and cleaned the electrical connections?
i put a new eccoder motor in it when i push 4hi i can hear the motor making noise under neith 4hi light comes on but doesnt engage 4low just blinks
where do the vaccum lines from the vaccum switch suspost to go there r 3 and where does the transfercase vent line go
Last edited by swartlkk; 10-01-2010 at 11:39 AM. Reason: Combining Consecutive Posts - Please edit your post to add additional information/questions if another member has not yet replied.
Put on all new vaccum lines took the transfercase motor off and it is working right. changed the actuator. the front drive shaft locks in when u put it in 4wheel drive when in 2 wheel you can move it by hand. The front tires are still not locking in 4 wheel.
Got the 4 hi working but still no 4 lo all lines are right, Was told that I have to adjust the transfer case motor is that true I see no adjustment setting on it any idea.
There is not an adjustment. Is the transfer case locking into 4LO? If it is, then your problem is with the vacuum system to the front axle.
The light blinks for 4 low but goes right out. I took it to a graduge and they put all new vacuum lines on it and they said they are all hooked up right. How do you know if the transfer case is locking in to low is there a way to check it 4 hi works perfect but no lo it just blinks and goes out
It sounds like you either have a problem with the encoder motor or the TCCM itself. Have a look through error_401's thread in the Tech Article (DIY) section linked to below for troubleshooting steps:
NV233 transfer case / encoding motor switch
I got my encoder motor warranted out and got a new one and still have the same problems. I tried testing the computer and i dont get no codes it dosent do anything. Still no low Guess I am goin to have to take it to the dealer and see what they say. The 60 a hr labor can add up fast.
mirrorimij
06-08-2019 03:34 PM
dannyb91979
07-16-2013 06:08 PM
lizzj70
06-23-2010 06:57 PM
