78 k5 stuck in 1st
Old Jan 17, 2010 | 05:55 PM
moe78's Avatar
moe78 is on a distinguished road
Default 78 k5 stuck in 1st
I have a 78 k5 blazer which 1st gear seams to be his only option. R N 1 2 3 4 are all 1st gear. The vacum is good any other suggestions?
Old Jan 17, 2010 | 07:16 PM
Manual transmission or Automatic? If it's automatic, then someone has swapped in a 700R4 cause it didn't come with a 4spd automatic from the factory. If manual, something has come loose inside the transmission. You'll have to pull the top cover and have a look inside.
Old Jan 17, 2010 | 07:32 PM
abig84's Avatar
you can check/change the vacuum actuator at the transmission. if that is broke or clogged. it could cause that
Old Jan 17, 2010 | 07:47 PM
If it's an automatic...
From the sounds of it though, it's a manual. Probably the SM465.
Old Jan 17, 2010 | 11:38 PM
abig84's Avatar
yeah re reading it im all confused now. a 4 speed in a 78... but he also mentions vacuum
Old Jan 18, 2010 | 11:38 AM
Also mentions that it is in 1st even though the shifter is in R, N, 1, 2, 3, 4... Need to get some clarification here.
Old Jan 18, 2010 | 02:00 PM
moe78's Avatar
It is an automatic with 1st gear as its only option meaning no matter what gear i put it in it is always in first even in reverse i go forward. Checked the vacuum its good
Old Jan 18, 2010 | 03:29 PM
abig84's Avatar
Even reverse goes forward? Does park work? Possible shifter issue?
Old Jan 18, 2010 | 10:51 PM
moe78's Avatar
yep even in reverse i go forward.
Old Jan 19, 2010 | 06:37 AM
Doesn't sound like the shift linkage is connected... Can you manually shift it at the side of the transmission?
