89 s-10 Blazer occasionally won't shift gears
Old Jan 21, 2012 | 10:08 AM
medako's Avatar
medako is on a distinguished road
Default 89 s-10 Blazer occasionally won't shift gears
This just started, when driving...everything is fine then go to shift gears and it will come out of whichever its in but then trying to put it in any other gear doesn't happen.
Pull over and turn off the engine, on restart (which seems to hesitate) I can get it into gear and it seems ok. Happened twice now.
Any ideas?
Old Jan 21, 2012 | 12:24 PM
blazer_grl's Avatar
blazer_grl is on a distinguished road
How's the level and condition of your trans fluid?
Old Jan 21, 2012 | 12:50 PM
medako's Avatar
Good on both counts.
Old Jan 21, 2012 | 12:58 PM
blazer_grl's Avatar
Manual or automatic? Forgot to ask...
Old Jan 21, 2012 | 11:44 PM
medako's Avatar
5 speed manual
Old Jan 22, 2012 | 07:30 PM
ctyler's Avatar
ctyler is on a distinguished road
I wouldn't think shutting it of and resarting would do anything.
Have you tried double clutching?
Is the linkage loose and/or jamming?
Does this happen with a particular gear everytime, like 2nd to 3rd?
Old Jan 23, 2012 | 09:23 AM
medako's Avatar
No, its all the gears, including reverse.
I have not tried double clutching yet...will try when I get home. Thanks
Old Jan 23, 2012 | 08:14 PM
ctyler's Avatar
Sounds like the linkage may need adjusted or a possible worn fork. When you shift gears make a concious effort make absolutely sure its solidly shifted into the next gear. This may be hit or miss but If that helps its probably the linkage or shift fork.
Other possibles are a worn bearing or syncro.
CleverName
Oct 28, 2014 11:54 PM
cavired99
May 12, 2014 10:27 PM
James1965
Jan 16, 2012 11:32 AM
Indy2011
Jan 25, 2011 02:04 PM
pigmak
Jun 25, 2009 06:12 PM
