89 s10 blazer clutch problem
My blazer is leaking clutch fluid, i dont know where it is going because i see no leaks under the blazer. It will be random, i will refill the clutch resovoir the night before overnight it will empty come the morning the clutch pedal is soft and i need to add more clutch fluid. also when im driving at times the clutch will just go soft and i need to pull over and add more clutch fluid. I got under it today to check it out and i saw a small plate that had 4 screws that had fluid all around it, i dont know if that is much help. I don't know very much about cars but im getting to know my blazer pretty well. I just got my clutch changed about a year ago. Any feedback, advice, suggestions would be nice.
see if its leaking inside the truck on the drivers floor. ive had that happen on my 85 and it would just leak right out the rust hole in the floor.
MintyMadness
07-13-2011 12:37 AM
