92 Full size high temp???
Hey guys got a 92 full size with a 350.. shes reading 235* most the time and somtimes rapidly drops to about 210.. had the system flushed,put new water pump,radiator, thermostat,and fan clutch but the temp stayed the same? Is this normal? Also had an aftermarket gauge put in just to see but reads the same. Any input or suggestions?.should i install a colder stat? Currently has a 195.
Motor has 190k on it.. nothing is hanging fron the grill. And it happens everyday highway or city.... if i let it sit there and idle most of the time it will only stay in the 215 rang but if i start to actaully drive it goes up.
It sounds like there is still air in the system. Air can cause coolant not to flow properly though the head, especially the back part of the head which is where the coolant temp sending units are typically installed.
Try running the truck through several warm-up/cool-down cycles with the front of the truck elevated, cap side of the radiator slightly higher than the opposite side, with the radiator cap off.
Tried bleeing it agian today but nothing i had already gotten it all out... could it be a headgasket issue? Oil doesnt seem to have any coolant in it. But i can be in stand still rush hour traffic and temp will stay in normal range.
