92 s-10 starting issue
Old Aug 6, 2013 | 05:07 PM
jsbcweese@gmail.com's Avatar
jsbcweese@gmail.com is on a distinguished road
Default 92 s-10 starting issue
I've got a 92 s-10 blazer with a vin w vortec in it that wont start what shoud fuel pressure be when you turn the key on and what should it hold at?
Old Aug 6, 2013 | 06:36 PM
bear159's Avatar
bear159 is on a distinguished road
I believe the fuel pressure should be 60 to 66 psi, and when at idle decrease about 3 to 10 psi. I have not done this in a while but I'm pretty sure those are the numbers.
Old Aug 7, 2013 | 12:18 AM
my pressure bleeds of right away eve after replacing the spider with new regulater what else could cause the pressure drop? also I hear the pump activate when I turn the key on
Old Aug 7, 2013 | 10:06 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
the fuel lines under the upper intake can leak too. What did it look like under the plenum?
cgrett
Nov 15, 2010 09:08 PM
sweet-98ta
Dec 16, 2009 08:47 PM
Sprocket
Mar 20, 2008 09:39 PM
Ptownblazer
Jun 18, 2007 11:34 PM
MDTjettaguy
Apr 3, 2006 05:17 PM
