92 s10 blazer. No codes won't down shift.
My Blazer wont downshift when I apply throttle at 35 + miles an hour. Not throwing any codes. New plugs new wires new distributor new transmission filter new shift solenoid. Don't know where to look please help
This is a 1992? If so you won’t get transmission codes as it is a hydraulic unit. Only solenoid in that will be a lock up solenoid. You need to check TV cable adjustment or a hanging governor.
Originally Posted by Transman304
(Post 691121)
I have changed the knock sensor, shift solenoid, and the trans filter. again, I appreciate your input/advice |
Still no improvement... Starting to think it might be the engine after all. But she runs fine in park only has the problem when I'm driving. Engine bogs and misfires,also won't shift. No codes. New governer, "tcc" solenoid, knock sensor, distributor,and tranny fluid. HELP.
Only 100,000 miles
Downshifting in 92's should be governed by two instances.
The first one being vacuum. The second one being kick-down switching. Not sure how it was built in the 92. AFAIK it could be a T700-R4 or a 4L60. Don't think the 92 already was a 4L60E. I think those came 93 or even only 94. Now the question is: Does it "not" downshift at all or does it only downshift when you hit the kick-down? |
(Post 691197)
Interesting. IMHO it's also pointing to some other source of the troubles.
Vacuum leak maybe? |
| All times are GMT -5. The time now is 06:46 PM. |
