92 s10 blazer. No codes won't down shift.
Old Jun 5, 2018 | 07:12 AM
Transman304's Avatar
No vacuum modulation on 700R4. Uses throttle valve to control pressure through cable. I would look into the backfire issue you are experiencing. There also is a downshift valve that may be sticking or spring broken.
92 s10 blazer. No codes won't down shift.-8b712520-0edf-4e3f-8b04-8ee46fbecf94.jpeg
Old Jun 5, 2018 | 09:28 PM
Blzerfan's Avatar
Blzerfan is on a distinguished road
Interesting. IMHO it's also pointing to some other source of the troubles.
Vacuum leak maybe?
not that I can find.. I hooked up all my vacuum lines when I replaced the distributor. It fixed my 4x4 and a.c. and my cruise control but not this issue. I've got to be missing something
Old Jun 6, 2018 | 04:38 AM
See Transman's advice. It's sound if all other things are up. Addressing the engine issues may also solve the transmission problem.
Old Jun 6, 2018 | 07:09 PM
Blzerfan's Avatar
thank you both. Im just home from work and getting on it now. Fingers crossed
gwi zerokool
Feb 13, 2013 07:09 PM
atl_finest
Aug 15, 2012 08:43 PM
teamrojasx2
Aug 16, 2011 10:51 PM
lobrist
Jun 19, 2011 07:29 PM
LMP1327
Feb 10, 2010 03:09 PM
