94 4.3L v6 Blazer Engine code W, starter and idle problems
Im pretty sure its W...
Anyways, i need to replace the starter solenoid but every time i go to do so the damn starter doesn't want to come out. The two bolts come out fine and the starter comes loose but there doesnt seem to be enough room to completely remove it.
And also my blazer has a terrible idle. It idles bad and sometimes dies. I replaced the fuel filter which was really clogged and no help. I cleaned the throttle bottle with a can of throttle body cleaner...looks brand new but yet again, no help. So if you have any suggestions for that also. I also go to accalerate it with the butterfly switch on the engine and it seems to starve for air or gas or something then revs up after a split seconds.
Suggestions?
Suggestions?
RE: 94 4.3L v6 Blazer Engine code W, starter and idle problems
Have you checked the EGR valve? It probably needs to be cleaned and a 'clean screen' gasket used to reinstall it.
IAC could need to be cleaned, as well.
the starter will come out. Its a tight fit, but it does come out.
You do have to remove the wires before you attempt to take it out.
Once the wire are off and the torque converter shield are off (at least loose so oyu can move it out of hte way) then tip the starter at a 45 degree angle faceing down, now tip it 45 degrees on its side, it should slde between the frame, exhaust, and anything else in the way.
Thank you so much.
You have helped me in the past too.
Always great help from this site.
your wlways welcome.
good day, I have the same problem removing the starter but when it came time to remove the wire on the selenoid the nut and bolt when turning together. So I cannot remove wire, does any one have a suggestion.
thanks
thanks
That is not fun when the stud into the solenoid spins. You can try getting something up in there to push against the connector on the wire to offer some resistance as you try to loosen the nut, but space being as it is under there, that may be quite difficult.
The other option is to just cut the wire and then splice in a new section of wire and a new connector once the starter is out. Just be sure to use the 3M butt connectors with heat shrink tubing and glue inside for the splice connection.
Tony1987mustang
04-10-2014 11:33 AM
optimus485
05-12-2012 07:07 PM
blazer chris
12-08-2011 09:56 AM
