94 s10 blazer meets a tree soon!!!
Old Dec 18, 2011 | 04:30 PM
jbordley19's Avatar
jbordley19 is on a distinguished road
Default 94 s10 blazer meets a tree soon!!!
i have a 94 chevy s10 blazer. cant seem to get the timing right its either too far advanced or retarted. but it was driving fine untill today, it started backfiring and bogging under accleration. it has the poorest idle when it wants to idle. any help would be greatly appericated.. thank you
Old Dec 18, 2011 | 10:40 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I have only two suggestions:
1. Make sure you're following the proper procedure to put the computer in bypass mode to set the timing. I've never done it on a Blazer but I know there's a particular wire you need to ground.
2. Check your EGR for carbon blockages.
Old Dec 18, 2011 | 10:45 PM
chevyblazer9588's Avatar
chevyblazer9588 is on a distinguished road
Do your '94 S10 Blazer have to be time by the computer. Because I had to take my '95 S10 Blazer to the shop and they had to time it from the computer and not with the time gun then it ran alot better. Just something you might want to ask.
Old Dec 19, 2011 | 06:30 AM
jbordley19's Avatar
i followed all the preceedures to the T. and no obd1 you manually have to time. obd2 is 95& up and the computer controls the time.
Old Dec 19, 2011 | 07:50 AM
The ECU still does control spark timing in your truck. In order to properly time the older ignition systems, you must first disconnect the brown (or brown with a tracer line on it) wire inside the truck, to the passenger side of the transmission tunnel, slightly below the top of the carpet at the firewall. If you didn't do this, you didn't properly set the base timing.
Old Dec 19, 2011 | 10:39 AM
At least I learn something new now.
Old Dec 19, 2011 | 11:50 AM
jbordley19's Avatar
yes, i did disconnect the connector. i pulled codes for a map sensor and a tps sensor and replaced them. now i have codes for a knock sensor and ignition circut malfunction. now it idles fine except for it surging here and there but as soon as you hit the gas pedal it feels like it has a miss and once you get it to 3000 rpms the check engine light comes on and it spits and sputters and then the revs up to 4000 and drops down to 3000 again like it shut off and it will keep doing it untill you stop.
i am starting to think fuel pump or spider injectors.
Last edited by swartlkk; Dec 19, 2011 at 12:10 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 19, 2011 | 12:25 PM
Do you hear any rattling at all when the engine is running? I'm thinking you might be chasing symptoms and not necessarily the problem. You may have a clogged catalytic converter. To narrow it down, try disconnecting & removing the O2 sensor ahead of the catalytic converter. If the truck runs as it should (minus the check engine light for the missing O2 sensor), then the converter is clogged and needs to be replaced.
If you don't have a converter, then you may want to test the compression & cylinder leak-down to see if you may have another mechanical problem that may be triggering the knock sensors, decreasing performance.
Old Dec 19, 2011 | 02:59 PM
jbordley19's Avatar
no cat on it. theres always been a very faint taping, or knocking.
kavanagh003
Shows & Clubs
29
May 11, 2012 01:00 PM
LucasMI
Feb 24, 2012 02:59 PM
JohnnyBlaze79
Shows & Clubs
Sep 18, 2010 08:04 PM
97Bravada
Shows & Clubs
16
Feb 19, 2010 06:45 PM
Sdyme Blazer
Shows & Clubs
Feb 8, 2010 08:50 PM
