94 S10 Blazer oil leak
Old Aug 30, 2021 | 06:59 AM
DutchBlazer94's Avatar
DutchBlazer94 is on a distinguished road
Default 94 S10 Blazer oil leak
Hello,
I'm from the netherlands and recently purchased a Blazer S10 from 1994. It's my first american car and jesus it's a sweet machine. I drove it home for about 200km's and when I parked it it developed a bad leak.
From what I've seen so far it's coming from the rear right side of the engine (passenger). It's dripping onto the frame rail and making it's way down.
I'm going look at it this week with a mechanic friend, was hoping any of you have any sugestions of what it might be, or could be.
it has oil all around the underside of the engine and transmission so I think I have to redo oilpan gaskets anyway.
Old Aug 30, 2021 | 05:15 PM
Can be from several locations.
Probably washing it down properly and then looking for the leak is the way to go.
Head gaskets usually do not spill a lot of oil if any.
Oil pressure sensor attachment can be one source of oil at the back of the block.
Oil pan gaskets are not known to leak but giving it a re-torque would clarify it that could have been the source.
Front crank oil seal might be a source.
A bad seal at the oil refill cap and tube could be a source.
The gasket between the plastic valve covers and the heads could be a source.
Old Aug 31, 2021 | 12:57 AM
Thanks!
That'll atleast give us some options to go through if we don't find anything right away!
I laid underneath the car at midnight and cleaned the framerail with breakcleaner to see if I could source the leak. When I went out in the morning it was wet again...
louiepb
Jan 7, 2012 09:34 AM
importsky22
Sep 25, 2010 10:39 PM
1sexyblzr
Jun 15, 2010 01:54 PM
musclecar70sfan
Apr 24, 2010 01:41 PM
Eternal15
May 30, 2005 11:26 PM
