94' wont start
Old Sep 8, 2007 | 11:05 PM
Fonwonox's Avatar
Fonwonox is an unknown quantity at this point
Default 94' wont start
my 94' 4.3 vortec turns over fine, but when it comes to firing up, no go. would this be because of a "dead" fuel pump, or for some reason an electrical problem/ no sparks from plugs?
Old Sep 8, 2007 | 11:10 PM
Default RE: 94' wont start
Well, you really need to test the fuel pressure to point at a fuel delivery problem...
Old Sep 8, 2007 | 11:12 PM
moe_23's Avatar
moe_23 is an unknown quantity at this point
I just had this problem with my 95 vortech, mine ended up being my fuel pump. check your pressure either at the fuel line right before the filter it should be located on the frame on the driver side, or at the schrader valve which is at the back of the intake on the driver side. you should have at least 50 psi. if you have pressure then check for spark.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
