95 4.3 lower intake manifold question
Old Jan 19, 2014 | 02:44 PM
nbrittenham's Avatar
nbrittenham is on a distinguished road
Default 95 4.3 lower intake manifold question
Hello all, I have a question regarding a 95 s-10 blazer 4.3 lower intake manifold. I searched around and could find anyone with a similar issue so I figured I'd ask. So I recently dug into this motor to change the head gaskets and when I took the lower intake manifold off i noticed that on the back of the manifold where the blocked off ports are look like some one attempted to drill it out. It also looks like someone spread rtv over their drill holes to fix it. My question is if I should reapply the rtv and attempt to reinstall it or should I start digging around the junkyard for a new manifold. The holes are contained by the gaskets but I'm worried I'll get this back on and it will leak or even blow the gasket. Any thoughts would be greatly appreciated. Thank you in advance.
Old Jan 19, 2014 | 03:20 PM
iowajoe's Avatar
iowajoe is on a distinguished road
don't know if it would cause problems but would replace it anyhow
Old Jan 19, 2014 | 04:51 PM
I think I'm inclined to agree you, I'm not very comfortable putting that thing back in the car like that. I definitely don't want to be tearing this motor apart again in a week because it failed. I'm thinking I'll head down to the youpull it and see if i can find another one. I'm still a little confused as to why someone would even try to drill this in the first place, it doesn't seem like it would benifit the vehicle. Anyhow thanks for your reply
Old Jan 28, 2015 | 01:48 PM
A Girl N Her Truck's Avatar
A Girl N Her Truck is on a distinguished road
Default same holes
The gaskets I bought for my manifold had nubs that fit into those holes, they help keep it from shifting when putting it back together
Old Feb 7, 2015 | 06:28 PM
v6vortec's Avatar
v6vortec is on a distinguished road
hope someone can help,1992 blazer s10 with a 4.6 vortex engine, the problem it will crank but no start unless I spray some kind of starting fluid but then dies but also if I take the intake of it will start run fine. can anyone help with any ideas.
Kknd310
16
Mar 27, 2012 06:16 PM
darin89
Aug 18, 2011 03:07 PM
ded2klf
Nov 29, 2010 10:15 PM
xxdaveyxx14
May 16, 2009 01:51 PM
vagnozzi
Sep 14, 2007 08:40 AM
