95 Blazer 4X4 issue
Old Dec 1, 2010 | 07:11 PM
RPM21's Avatar
RPM21 is on a distinguished road
Default 95 Blazer 4X4 issue
Hi, i have searched through these threads and i cant seem to figure out whats wrong with my 4X4? i have a 3 butten system. i have a cable going inside the cab to pull on the actuator cable, and i know that the front differential is engaging. i jacked the front end up and turned a wheel.. anyway. when i push my 4 HI or 4 Lo buttens nothing happens... sometimes both the 4 Hi and 4 Lo lights come on, sometimes they just blink and go back off. i can hear the electric motor on the transfer case make noise. but 4 wheel drive still doesnt work? any help would be greatly valued! thanks
Jevon
Old Dec 1, 2010 | 07:27 PM
Have you tried to pull the codes as described in either of these two threads:
OBD2 NV233 Diagnostics
NV233 transfer case / encoding motor switch
Old Dec 1, 2010 | 07:42 PM
RPM21's Avatar
i have been reading these threads for a little bit now... i have no way of trying to pull any codes tho?
Old Dec 1, 2010 | 07:47 PM
So you don't have a paperclip? If you have an OBD2 equiped '95, ground terminal 13 on the DLC. If you have an OBD1 '95, ground terminal J or short terminal J to A. With the jumper in place, turn the ignition to RUN and watch the 4wd switch.
Old Dec 1, 2010 | 08:18 PM
RPM21's Avatar
im kind of confused here, i pulled the 3 butten switch out of the center of my dash now, and im not seeing a "J" on it? am i looking in the complete wrong place here?? or something?
Old Dec 1, 2010 | 08:21 PM
Yes, you are looking in the wrong place. You need to look for the diagnostic link under the dash.
Old Dec 1, 2010 | 08:37 PM
RPM21's Avatar
ok i grounded # 13 and my 4X4 lights all three of them blinked 2 times?
Old Dec 1, 2010 | 08:39 PM
Code 2 is an encoder fault. Check the OBD2 NV233 Diagnostics link above for the diagnostic steps for this code.
Old Dec 1, 2010 | 09:04 PM
RPM21's Avatar
alright thanks for the help, ill see what i can do tomorrow night... as of now... bed time! talk to you later!
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
jimhens82
Dec 17, 2009 06:32 AM
