95 Blazer cranks wont start
How old is that battery? Assuming that the connections are clean and tight at the battery terminals it’s acting like it’s failing. If it’s more than 3 years old you should consider replacing it. If you would rather be sure you can have it load tested first. There is an outside chance that the starter is bad but load testing the battery would confirm which it is.
George
George
The fuel pump cannot draw enough current to cause the start voltage to drop that much unless it is defective or there is a short but then it would blow the fuse. 2.5 years is an early battery failure unless it’s a budget brand or it’s been allowed to sit depleted, this reduces the useful life by causing sulfation on the lead plates.
Before you do any further testing make sure that you have a known good battery charged to 12.6 volts with the surface charge knocked off after charging ( headlights on for 15 sec). The voltage during cranking should not drop below 10v. A battery load test simulates the 100a ish current draw of a typical start sequence to see how well the voltage holds up.
George
George
George
George
George
Leaking fuel pressure regulator and/or 'nut kit' (interal fuel lines), both of which are inside the intake plenum. Time to pull the upper plenum off and have a look inside. You can remove the upper plenum leaving the fuel system intact which will allow you to pressurize the system and inspect for leaks.
Once you find the leak and get it repaired, you'll have some cleanup to do before you can fire it up again. I would pull all of the plugs and spin the engine over with the starter after disabling the fuel pump. Then squirt a little engine oil into each cylinder and spin it over again to relubricate the rings. After that, change the oil to remove any chance of fuel contamination and reinstall the plugs. After all that you should be good to actually start the engine.
Thank you for your advice, I will be sure to do all that cleanup before I try to actually run it again. Should I replace the spark plugs as well? The current ones are brand new, I just removed them in order to drain the fuel out of the cylinders. The oil and oil filter are pretty much new as well but I will change those just to be safe.
