95 Blazer No Oil Pressure
Old Nov 2, 2009 | 01:32 PM
dredin89's Avatar
dredin89 is on a distinguished road
Default 95 Blazer No Oil Pressure
My blazer takes for every to start. When I try to start it, I have to hold the ignition on while the engine try to turn over for 15-20 seconds until finally the oil presure comes up. The entire time I'm trying to start it the gauge will read 0. Eventually the gauge will start climbing, when it does the engine starts. Does anyone know what could be causing the delay in the oil pressure building up enough to start the engine.
Thanks.....
Old Nov 2, 2009 | 07:01 PM
cc4usa's Avatar
cc4usa is on a distinguished road
try replacing your oil pressure sending unit or put in a T and hook up an actual oil pressure guage to check if your oil pump is going out
if you dont have enough oil pressure the computer can keep your engine from running to prevent damage
Old Nov 2, 2009 | 11:32 PM
biniecki's Avatar
biniecki is on a distinguished road
Where is the sending unit located? My gauge is broken on the dash and would like to possibly install an aftermarket one just so I can keep an eye on it.
Old Nov 3, 2009 | 07:27 AM
cc4usa's Avatar
if your talking about a 95 its back by the distributor
buy a chiltons repair manual. best book for info since motors quit printing manuals years ago. damn them
Old Nov 3, 2009 | 09:34 AM
biniecki's Avatar
Well I have a 96. I would assume its around the same area.
Old Nov 3, 2009 | 09:36 AM
It is. The oil pressure sending unit is located on the back rail of the engine block between the distributor and the brake booster. It is a "fun" job to replace it! LOL
Here's an image for the 96+ engines:
For the older CPI engines, it is in the same location, but much harder to get at due to the size of the intake plenum. The image below is of the lower intake. The oil pressure sending unit is located just to the left of the #9 in the image below where there is a semi-circular notch in the lower intake.
Old Nov 3, 2009 | 12:25 PM
biniecki's Avatar
Thanks for the info. I think more or less the gauge is just messed up on my cluster. The needle is always all the way to the right bottomed out. I think the needle or something is broken on it. More than likely if possible I would replace the stock sending unit with an aftermarket one and connect a different gauge.
Old Nov 3, 2009 | 12:32 PM
It is possible for the needle to have worked loose on the gauge shaft. You could try pulling the cluster and resetting the pin to the zero position with the cluster connected, key on, engine off.
Old Feb 4, 2010 | 08:39 PM
bl95vrtc's Avatar
bl95vrtc is on a distinguished road
T ftw
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
