95 blazer runs bad
well i replaced the fpr and did the plugs but it wont start and theres gas in my oil so i feel as if im pretty much screwed
If there is gas in your oil its probably your fuel spider & or FPR has been leaking. While you've got the intake off you can pressurize the system and see if anything is leaking.
nothing seems to be leaking my plugs are getting full of gas so im thinking maybe its my wires to my plugs
i just replaced the fpr because it was leaking but now it wont start it started befor and ran then shut off and has stayed off
From what I understand, on our engines, there's several things that can make them run rich. I suppose one can run so rich it would wash down the cylinder walls and get gas in your oil. I would be absolutely sure that there is nothing leaking under your intake being as you say there is gas in your oil.
Maybe someone else will chime in that knows more than I.
I'm having trouble with my 92 S10 Blazer, right now I'm waiting on a repair Manuel so that I can better understand these sensors, check them and the wiring out. I've been messing with it for about 2 or 3 weeks. It tough on this old year old man to check out this computer stuff. I trying my best to keep from having to take it to a shop.
Edited to add this:
All I can think of is make sure all wires are plugged back up and making a good connection. If that checks out run a pressure check.
Edited to add this:
barnesto
31
06-11-2014 07:12 PM
zakm0n
01-10-2011 11:42 AM
pinktruck
08-10-2007 08:52 AM
95s10bazer w motor
02-27-2006 03:03 PM
