95 blazer wont start
Old Feb 17, 2011 | 06:33 PM
mark stargell's Avatar
mark stargell is on a distinguished road
Default 95 blazer wont start
my 95 blazer wont start but when it does it chugs and choks itself out and cuts off. i have replaced the spider assembly plugs and wires new coil new fuel filter and pump. i thought it was the cat but it seems like it isnt getting enough fuel. any help would be awesome
Old Feb 17, 2011 | 06:39 PM
Have you tested the fuel pressure & leak down rate to see if you still had fuel leaking from somewhere and/or enough fuel pressure? If you didn't replace the 'nut kit' (internal fuel supply & return lines) when replacing the spider, you likely have a leak there now.
Old Feb 17, 2011 | 06:42 PM
no i havent tried that ince it wont start i dont have a way to check that by taking it to a shop or the knowledge to do it myself. when i first got the spider assembly fixed it ran for awhile then this happened.
im sure when they put it in im hoping that the shop that did it put it back
Last edited by swartlkk; Feb 17, 2011 at 06:45 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Feb 17, 2011 | 06:46 PM
Ok, so it did run for a bit then this occurred. Still could be a weak fuel pump or leak somewhere in the system.
You can pick up a fuel pressure gauge from just about any parts store for <$30. The fuel pressure test port is located off the back of the intake manifold near the brake booster.
Old Feb 17, 2011 | 06:50 PM
i dont think its a weak pump because i replaced the pump before any of this happened and it worked fine then the spider asembly went bad and got replaced. also i noticed that the cat got cherry red one night but hasnt since could it be a clogged cat?
Old Feb 17, 2011 | 06:55 PM
Anything is possible and you really need to verify it all. Just because a component was replaced doesn't mean that it couldn't have failed between then and now.
Old Feb 17, 2011 | 07:00 PM
i will thank a lot
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
