95 Chevy Blazer idles rough
Old Mar 2, 2011 | 05:26 PM
jamesf's Avatar
jamesf is on a distinguished road
Question 95 Chevy Blazer idles rough
I have a 1995 Chevy Blazer. It runs rough at times and also has a problem of high RPMs when it starts up occasionally. Every couple of days when you start it up it will rev up to about 2500 RPMs. Any ideas?
Old Mar 2, 2011 | 10:27 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
rough idles are the stomach ache of vehicles. Almost anything can cause it, more information is needed to know what is going on. How much vaccuum pressure do you have?(should be around 17 in of Hg) Whats the fuel pressure and does it drop when you turn the key off? When was the last tune up done? Have the O2 sensors every been changed? how clean does the area around the intake by the butterfly valve look?(assuming you have CPI and not TBI)
Old Mar 20, 2011 | 08:05 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Is it throwing any codes? There are a ton of posts on this problem Under Misfire could be one of a bunch of things. I had a similar problem which ended up being the Cylinder #1 Rockers were torqued down to Z vin specs instead of W vin specs but do some research on this site
rabbitthunter1@gmail.com
Engine & Internal
Jan 8, 2013 10:12 AM
Blazerdave95
Sep 2, 2011 06:06 PM
nhguy261
Dec 30, 2010 01:41 PM
hubert hefner
63
Mar 16, 2010 11:29 PM
91Blazerblk
Sep 25, 2006 03:23 AM
