95 Chevy blazer starts after like 10 cranks
Old Dec 9, 2010 | 11:22 AM
1djcarlos's Avatar
1djcarlos is on a distinguished road
Default 95 Chevy blazer starts after like 10 cranks
I crank it, it starts of as if it's not getting gas, then after a 3rd or 4th crank it reacts as fuel has reached but won't start. After bout ten try it finally would start throughly and stay running with good idle etc. If I turn it off and let it sit for a second it starts right up. But then if I let it sit for over an hour it goes right back to not starting.
Old Dec 9, 2010 | 11:41 AM
You have a fuel leak. You can test fuel pressure at the motor and then again at the fuel filter to determine where the leak is occurring. Testing at the engine lets you know that the fuel pressure is actually bleeding off and testing at the filter eliminates the engine side of the fuel system leaving just the check valve in the pump.
On the CPI engines, the most likely culprit is the FPR followed closely by a toss up between the 'nut kit' (fuel lines internal to the intake) and the check valve in the fuel pump assembly.
How well does it start if you turn the key to the run position, wait for the pump to shutoff, turn the key to the off position, and repeat a few times?
Old Dec 9, 2010 | 02:15 PM
1djcarlos's Avatar
I tried a few ways of getting it to start,
But once it starts and stays on I can turn it off and it will turn on ok.
no fuel leak
Last edited by swartlkk; Dec 9, 2010 at 03:22 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 9, 2010 | 03:21 PM
What was the pressure? How long did it hold that pressure?
Old Dec 9, 2010 | 03:36 PM
1djcarlos's Avatar
i dont know yet. I gotta get a reader
Old Dec 9, 2010 | 04:46 PM
So how have you determined that there is no fuel leak?? You need a fuel pressure gauge to test fuel pressure.
Old Dec 9, 2010 | 05:42 PM
1djcarlos's Avatar
oh that kinda leak....i was looking for actual gas leaks.
Old Jan 15, 2011 | 03:46 PM
1djcarlos's Avatar
Default Update
Starter reads low cranking amps
o2 sensor reads low voltage
it starts up with starter fluid and stays running but when i shut it off and let it sit for 10 minutes or so it won't start right up unless ui put starter fluid.
kwbond
Mar 18, 2014 12:39 AM
jimspahr@msn.com
Oct 21, 2013 08:58 AM
bsbob
Jul 22, 2011 12:48 PM
JMAC
17
Apr 7, 2009 11:32 AM
nyjeepman
34
Mar 15, 2009 07:40 PM
