95 jimmy dies when shifting into drive/reverse
So for the last few days my ride has been having issues, first it wasn't getting enough fuel and would die unless i kept my foot on the gas, (fuel filter and PCV valve were both replaced then a high idle 1500-3500rpm. Ive order a new air control valve and TPS.
While I wait for the parts I went ahead and cleaned the Air control valve with some wd40 and a toothbrush. Thought everything was Ok drove it to work and it idled around 800rpm, Fired it up this morning idle was fine but as soon as i shifted into reverse to exit my parking spot the entire truck shook and Died/ IT did this in both drive and reverse. |
