95 motor to 96 truck
Old Mar 18, 2010 | 05:50 PM
thisbedan's Avatar
thisbedan is on a distinguished road
Exclamation 95 motor to 96 truck
ok i got a 95 blazer w code with a good engine bad trans and i got a 96 blazer w code bad engine good trans ive already started the 96 motor breakdown need to rebuld or swap, easier to swap . question is will the block and heads from the 95 work in the 96 i will be keeping all intake parts and manifold and valve covers on the 96 so no computer problems thanx
Old Mar 18, 2010 | 08:25 PM
Very different engines. The heads on up are different. The heads would have to have the intake drilling redone to match up to the 96 intake. Then, the timing cover could be different depending on which version of the '95 motor you have.
Old Mar 18, 2010 | 08:43 PM
bandidolenny's Avatar
The 95 engine probably will not have provisions for the cam / crank angle sensors that the 96 computer is gonna require... amonst other things as mentioned above.
Old Mar 18, 2010 | 08:57 PM
thisbedan's Avatar
ok ... humm i guess i should keep the heads also and check for the timing cover ..
bobby099
Dec 22, 2018 09:41 PM
bigdaddykane93
Jan 27, 2016 11:35 PM
er0ck273
Jul 31, 2015 04:10 PM
Keys6505
Mar 17, 2013 04:23 PM
LordOfWar
Dec 1, 2009 09:19 PM
