95 running rich
Old Jul 26, 2014 | 09:52 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Default 95 running rich
I have a 95 which does not make diagnostics easy. So far I have changed the TPS pigtail which helped a lot and fixed some shifting problems. That was followed by the front O2 sensor and exhaust donuts which has since improved engine vacuum affecting shift quality and it now fires off when I hit the ignition.
It still feels a little sluggish and smells rich most of the time. So at this point I'm leaning towards coolant or air temperature sensors being a little off. I'll do some searching so I can take readings on the sensors but it's hard to find the correct specs for most thermal sensors.
If anyone has other suggestions I'd like to hear them. I do have an air filter that needs installed. The cap/rotor and plugs were replaced about 2 years ago as well as intake manifold gaskets.
Old Aug 27, 2015 | 04:18 PM
TZFBird's Avatar
Follow-up:
As far as I can tell air and coolant were reading good. I ended up changing the spider injector and so far it's been better.
ksimpson
14
Oct 7, 2013 05:25 AM
Vince's04blazer
Jan 11, 2010 05:45 PM
uncledenny
Jan 8, 2010 04:09 PM
Smoked
Apr 8, 2008 07:43 AM
jdblazer
Dec 28, 2006 03:28 AM
