'95 S10 Blazer
'95 S10 Blazer
My wife just spun the bearings in our '95 s10 blazer 4wd. I figure I'll just pull and replace the motor, but I've been told I can only use that yr. due to a sensor under the timing cover? Is this true or can I use any yr. withing a yr or two of this one. Or could I just find like a core and swap all my intakes and what not over?
RE: '95 S10 Blazer
'95 is a bastard year, it is OBD 1.5. Not a OBDI like the '94 and not OBDII like the '96.
IF there is a sensor in the timing cover, swap it to the new engine. You will have to swap all the sensors over anyway and you may have to swap the intake manifold to get the correct fuel injection system. If you have to swap the intake, stay away from a '96 or newer. In '96 GM changed the angle between the heads and intake mainfold, and they changed the angle of the bolts holding the intake manifold in place. Your '95 intake wont bolt up to '96 heads.
A '93-'95 block should work in your case. Verify your timing covers are teh same. Count the bolts. I used to have a link to an excellent article about all the engine changes over the years, however puter issues has forced me to use a laptop for the time being and I dont have that link on this machine.
Swart may be able to post it up.
Dallas1970
02-22-2019 05:05 PM
94BlazerGirl
08-28-2014 06:14 PM
rfine67
08-13-2011 01:04 PM
1994BlazerS10
03-03-2010 08:52 AM
