96 4.3l 4x4 blazer no spark
Old Sep 20, 2007 | 11:57 PM
N.alaska_blazer's Avatar
N.alaska_blazer is an unknown quantity at this point
Default 96 4.3l 4x4 blazer no spark
starting out with a drivers side door speaker wire short (fixed), then killed the battery (recharged), fried the starter (replaced). found a security system under drivers access panel (your valet) with one set of wiring off?? located ignition coil dealerbooper next to oil dip stick n dunno wich is what for power to coil. i got no spark on vehicle, no manual and too expensive for a mech hear.
Old Sep 21, 2007 | 01:58 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Default RE: 96 4.3l 4x4 blazer no spark
you honestly have to explain a little better what you are looking for here. I could not understand anything out of that.
But anyways getting spark is always the same, make sure your battery is fully charged then check the ignition system (ie plugs, wires, cap, rotor, coil).
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
jerickso
Apr 13, 2006 02:24 PM
