96 Blazer Cutting Out
Old Jun 8, 2011 | 01:03 PM
Sans's Avatar
Sans is on a distinguished road
Default 96 Blazer Cutting Out
I have a 96 Blazer and when it's hot out and i'm driving the truck will randomly die on me. I have to wait 30 to 45 minutes before I can start it again and drive it. At that point I can only drive it for about 5 minutes. When the truck dies no lights come on and all the guages are fine.
I haven't tried anything yet but I was looking for some suggestions.
Old Jun 8, 2011 | 01:13 PM
ICM (ignition control module) and/or coil. Both can be susceptible to heat soak. The bad thing is that no one really carries the equipment necessary to test them anymore. It used to be that you could walk into just about any chain store and have them tested for failure, but no one around me does this anymore. If you have a buddy with a properly running 96+, you could swap these parts between the two trucks one at a time and see if there is any difference.
Old Jun 8, 2011 | 01:20 PM
Sans's Avatar
Unfortunatly i dont have a friend with a Blazer however if i take it to a mechanic should they try replacing the ICM prior to the coil or does it not matter?
Old Jun 8, 2011 | 01:36 PM
Replace them yourself! They are both relatively easy to replace. The coil is the cheaper of the two.
A good mechanic would diagnose the issue before replacing anything, but good mechanics are getting harder and harder to find.
Old Jun 8, 2011 | 02:06 PM
Sans's Avatar
Oh it is? Even better! I'll let you know if it works!! Thanks!
1996BlazerSD605
Jul 15, 2011 03:56 PM
greg94
20
Aug 31, 2010 12:57 AM
rlott43
May 10, 2009 06:30 PM
justDrivin
Apr 7, 2008 06:13 PM
xtreme01blzr
Oct 18, 2006 03:23 AM
