96 blazer- major issues
Old Feb 24, 2009 | 09:48 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
Default RE: 96 blazer- major issues
yeah just go back to carb, points, and distributor. why do they need to make things soo complicated. i think that its a good idea to change out the cap. those caps are really weird on the 96s.
Old Feb 25, 2009 | 01:09 PM
I would start with replacing the cap and rotor again just to make sure you did not just get some bad parts.
About the carb/points/etc. I would not go so far as to call points good. IMO, HEI blew points away for reliability and ease of use. But I digress, that is neither here nor there in this discussion. LMAO!!
Old Feb 25, 2009 | 01:41 PM
probie2356's Avatar
probie2356 is an unknown quantity at this point
ok so i replace cap and rotor rechecked timing, started up and same thing, but ran long enough to throw a code p1345-crankshaft position,camshaft positon correlation. just dont know what now. please help.
Old Feb 25, 2009 | 03:16 PM
bandidolenny's Avatar
I kinda hate to bring this up but... are you SURE that you lined up the cam correctly when you changed the timing chain?
Old Feb 25, 2009 | 03:20 PM
Check out this ==> P1345 Explained
If the cam was improperly timed to the crank, I would not think that the compression would work out to be as good... But then again...
NTeal
18
Jul 9, 2011 05:35 PM
dutchs98blazermarkIII
Nov 5, 2010 09:55 PM
Buck731
Dec 2, 2009 03:11 AM
cuzmo21
Sep 5, 2009 09:58 AM
cannibal440
Mar 3, 2008 01:43 PM
