96 Fuel Pressue
Old May 13, 2024 | 10:32 PM
  #21
coastie's Avatar
coastie is on a distinguished road
I went with the Eichlin, hopefully it holds up, this is not what I would call my favorite activity lol. Based on what I can tell the stock bracket "should" work with this upgrade. I ordered the other one just in case. Ill let you know how it turns out! Thanks again for all of your help.
Old May 13, 2024 | 11:13 PM
  #22
GeorgeLG's Avatar
Good luck.
George
Old May 14, 2024 | 08:59 PM
  #23
coastie's Avatar
OK I have it installed. I fired it up, and it went bananas, like it REALLY came alive, im talking 3500 rpms or more, I had to shut it down. Anyway there is a vacuum leak. Its coming from whatever the break booster line goes to on the plenum, I can not figure out that that part is called. It will not sit properly back down and twist in, I think it needs replaced. Do you know what that is called?
***UPDATE** I finally figured out what it was called. its this part number 12602245 Power booster brake vacuum tube fitting.
Old May 14, 2024 | 09:38 PM
  #24
coastie's Avatar
On second attempt, some WD40 got it to slide right in, almost like it was made for it.
It idles right around 1k, a touch under, so I'm pretty happy with that.
It still has a slightly rough idle, I'm hoping a tune up will take care of that. There could be a small vacuum leak somewhere I missed as well.
Old May 15, 2024 | 09:48 AM
  #25
GeorgeLG's Avatar
When you get a chance take a look at your 4 fuel trims to see how those injectors are doing and fuel control in general.
George
Old May 15, 2024 | 10:05 AM
  #26
GeorgeLG's Avatar
Also, inspect your air intake after the MAF for leaks/unmetered air.
George
majik211@yahoo.com
Aug 23, 2012 04:21 PM
Bhahn25
Apr 13, 2011 05:48 PM
Cidium
Apr 1, 2011 10:07 PM
steveiowa1
Aug 26, 2010 07:10 PM
kornphlake
Jun 8, 2006 10:24 PM
