96 s10 blazer misfires on #1 cylinder
Old Apr 16, 2011 | 06:18 PM
halfton24's Avatar
halfton24 is on a distinguished road
hey im stuck i have a 96 s10 blazer and i developed an occasional miss that turned into an occasional misfire. i had the codes read and it said misfire on #1 ive changed the plugs,wires, cap and rotor. the problem got a lot worse. now it misses at idle and when i rev the motor it misfires. i traced the vacuum lines and they seem fine, well all the ones on the diagram under the hood anyway. it sounds like i may have a doughnut gasket leak would this cause my problem? i should mention that i have the 4.3 vortec v6. any and all advice is welcome......
also i should mention that i tried to unplug the vac. line where it runs to the rear of the vehicle while it was running and there was no change in the motor
Last edited by swartlkk; Apr 16, 2011 at 06:39 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Apr 16, 2011 | 06:46 PM
A tune up should not have caused the problem to get worse. How did the plugs look?
If you have an exhaust leak in the area of the 'donut', it can throw off the O2 sensor readings causing a rich condition.
Old Apr 16, 2011 | 07:04 PM
halfton24's Avatar
the plugs where worn quite bad it looks like they where in the truck for some time. but would that cause the misfire issue?
Old Apr 16, 2011 | 07:06 PM
Plugs with too wide of a gap could definitely cause a misfire condition, but that 'should' have been remedied by the tune up.
What brand of plugs did you install? What were they gapped to?
Old Apr 17, 2011 | 04:12 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Another thing to make sure of is make sure none of the spark plug wires are touching, in cheaper sets the spark can jump across to another wire causing all sorts of fun things.
Old Apr 17, 2011 | 08:48 PM
jmd8074's Avatar
jmd8074 is on a distinguished road
If the misfire got worse after tune up it seems most likely that something went wrong with the tune up. Make sure plugs were gapped properly, make sure wires are going to the correct cylinders, cap n rotor both screwd down tight, and that you have all o the wires connected good at both ends. and NEVER use autolite plugs on a GM
Old Apr 21, 2011 | 10:57 PM
halfton24's Avatar
kk ill double check these things tomorrow. ill let you guys know what i find
Old Feb 3, 2012 | 03:45 PM
reifsara's Avatar
reifsara is on a distinguished road
i have a miss in my #1 cylinder too. i got my 96 blazer worked on a month and a half ago. the LIM needed replaced when i got it back i had a miss in the first cylinder and it was not there before it got worked on. the place told me i had miss and it could be the cylinder or the injector. i found out form a friend that when they took my intake manifold apart they had to remove the injectors and they could have been damaged in the process and that is why it has a miss now. the place that worked on it wont fix there possible mistake at their cost since they messed up so my friend is gonna work on it for me. the spark plgs and wires are fine according to the place that worked on it but i know i cant trust what they did because im having my blazer worked on again for overheating which the place was supose to fix. i was told the miss wasnt bad but it is you can hear it its slow to start and when its idoling you can feel it. what could cause the miss if the place didnt mess it up?
Tcannon408
Dec 27, 2020 01:41 PM
krazii
Jul 27, 2011 12:51 PM
mbar
Nov 10, 2010 02:39 PM
brettf516
14
Nov 11, 2009 06:05 PM
carlt1911
Mar 1, 2009 06:13 PM
