97 blazer 1351 code problems
Old Dec 25, 2013 | 11:36 AM
bige97blazer's Avatar
bige97blazer is on a distinguished road
Default 97 blazer 1351 code problems
Looking for some help with this 1351 code, the problem is some what interrmitent. Haven't linked to weather ect. Acts up pretty much when it wants. Engine cranks but won't start. Then all of a sudden it starts. Runs good for a week ect, then won't start. I have replace icm with new ac delco. terminals were worn/spread open in plug and I replaced all of them with new. I am a truck mechanic with a snap on modis. I have power and ground to ICM . Continuity from ICM to coil on wht/blk wire. Testing to VCM and schematic shows wht wire 9 C3 (gry) . On VCM there is red, blue, white and black. And a 5 pin gray plug with only 2 white wires in it. By location i think the wire is in pin 9, connector 3, which is gray. But the gray connector only has 5 pins. Right now it won't start. Do the VCM's go bad? I've looked over harness and don't see any visible rubbed thru spots. Any help would be greatly appreciated.
Intmid8r
Nov 8, 2014 07:54 AM
optimus485
May 12, 2012 07:07 PM
92s10Blzr
Dec 7, 2009 03:12 PM
upblazer95
Apr 4, 2009 08:27 PM
lostatsea85
Jun 30, 2008 10:06 PM
