97 blazer transmission 1st & 3rd gears only??
Old Sep 11, 2008 | 10:16 PM
zionatdirt's Avatar
zionatdirt is an unknown quantity at this point
Default 97 blazer transmission 1st & 3rd gears only??
Hello all...I am the new owner of a 97 blazer with a bad transmission.I have learned that people who already own these trucks will be the best to help. History: she said one day it started out from 1st gear,banged into 3rd(skipping second) and never shifted to overdrive (no reverse either).She parked it.I have acquired it for my 15 yr old daughter.I drove it home and yes it is exactly as described.Before I left I checked the trans fluid,it didn't register on the dipstick while running.Two qts topped it off and the trans fluid looked clean.I drove it home with 1st & 3rd seemingly working fine.I am not familiar with Chevy so I am looking for 2-3 starting points for diagnosis.Usually when I help others I start with the best scenarios first getting to the worst.I am not really in a hurry but certainly curious as to what kind of deal I got for $300 in trade.Thanks in advance to anyone who can get me started. Dave
Old Sep 12, 2008 | 06:57 AM
Default RE: 97 blazer transmission 1st & 3rd gears only??
Busted sunshell. Common in the early 4L60E transmission. If you are confident enough to rebuild it yourself, more power to you. I just had a coworker have his sunshell replaced by a local shop (no rebuild) for roughly $500.
Old Sep 12, 2008 | 10:48 AM
zionatdirt's Avatar
Well that was easy...thanks Kyle.I will start learning about this "sunshell" Dave[sm=thanx.gif]
Old Sep 12, 2008 | 11:23 AM
Check out this thread:
4L60E Tranny Rebuild Thread - by Tim Hanr (hanr3)
I highly recommend you buy the ASTG manuals for the 4L60E if you are considering doing this yourself.
Old Sep 14, 2008 | 11:52 AM
bzmotoninja83's Avatar
bzmotoninja83 is an unknown quantity at this point
i had the same problem in my 94 s10 4.3. the local trans shop said i had "snapped" the band for 2+4th gear.
Old Sep 14, 2008 | 03:10 PM
The key is in the "no reverse either" statement. I am very confident that the reaction sunshell is the cause of this problem.
Old Sep 15, 2008 | 12:31 PM
zionatdirt's Avatar
Thanks for the info...still trying to decide if this is worth fixing.These threads sure are helpful,thanks.
Old Oct 21, 2008 | 03:08 PM
zionatdirt's Avatar
I feel confident it is the sun shell gear.I have an uncle that lives 6hrs away who is retired willing to help and has a heated garage with lots of tools.My question is: Should I risk driving that far with the transmission in its current state. 1st & 3rd seem to work real strong.I have driven 80 miles already in this current situation.Any thoughts would be appreciated. Dave
Old Oct 21, 2008 | 03:47 PM
zionatdirt's Avatar
One other thing.I crawled under there but how do I find out for sure what model transmission I have.Want to be sure before I order parts.It did come with a factory towing package. Thanks much, Dave
Old Oct 22, 2008 | 08:10 PM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
look to see if you have a case oil pan or a stamped steel one...my 96 has the 2 peice case
