97 Blazer Won't start!
Old Jul 13, 2012 | 02:06 PM
caprini83's Avatar
caprini83 is on a distinguished road
Default 97 Blazer Won't start!
So the other day I was driving home from work truck started losing power I was able to make it home. I noticed that then I was at stop lights it idled just fine, but when I would give it gas it would bog down and once I let off the gas it would backfire. I let the truck cool down, I went back out to start it and see if the issue was still there... The truck wouldn't even turn over and run (by turn over I mean the starter is fine the motor just wont fire off) I can hear the fuel pump kick on when I turn the key, the fuel filter was just replaced 3 months ago. I thought maybe it was spark plugs, wires, cap and rotor so I replaced all that today and still nothing. I'm at a little bit of a loss as to what it could be now, I'm thinking spider injectors or maybe the fuel pump just doesn't have the power to push enough fuel.
Old Jul 14, 2012 | 12:34 AM
50lb_cat's Avatar
Do a fuel pressure and leakdown test. Hook up a fuel pressure gauge to the schrader valve on the fuel rail. Do the test with te key on, engine off. Your initial number should be about 60 to 65 and shouldn't leakdown below 55 within 10 minutes. Post back your initial number and 10 minutes later number.
Old Jul 15, 2012 | 01:44 AM
caprini83's Avatar
I have no idea how to do a leak down test or the tools I will need to do it... If someone could tell me what I need to do the test and maybe pictures of how and what to hook the tools up to... I will do some Google searching in the mean time.
Old Jul 15, 2012 | 01:58 AM
50lb_cat's Avatar
https://blazerforum.com/forum/tech-articles-diy-29/96-fuel-system-diagnosis-23038/
That should help. You can rent the gauge from autozone. Basically you leave a deposit and you get your money back when you return it.
Old Jul 17, 2012 | 01:30 PM
caprini83's Avatar
So I just did the leak down test... when I turn on the key and let the pump prime the gauge is at 45 and then leaks down to 30, so bad fuel pump?
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
