97 Chevy Blazer erratic fuel gauge
i have a 97 gmc jimmy 4.3 i have some of the same symptoms as others. My gas gauge goes eratic i can crank and crank but it wont fire. If i pour fuel into the throttle body i can get it to start then i can get it to start and it will stay running but after i shut it off and it cools down then i got to pour gas in the throttle body again to get it to start. Could this be as simple as replacing the fuel pressure sensor as well or could it be the spider injector
My father S-10 (brazilian made, 2.4 liter engine) have a similar behavior and it was a bad hose (the fedding line to engine). Of course that thing cames pretty obvius if leakage is at a visible point, but if it at the tank could be different.
And do what swartlkk says, i had a "fuel pump" problem and instead to buy a 600 bucks fuel pump assembly (yeah, those things are pretty costly in Chile.. and that is the cost of Cartier Pump.. AcDelco is much costly!!!) I found out a melted pin and replace wiring even inside tank.
The misfiring code could come from out when you don't have enough fuel pressure, but it could be a clogged poppet valve.
MarkyMarc
17
Mar 8, 2013 08:25 PM
mtsumedi
Apr 10, 2011 04:49 PM
ForkliftJeff
Sep 24, 2007 05:30 PM
