97 s10 blazer engine
Old Jun 30, 2012 | 02:49 PM
cali bear 87's Avatar
cali bear 87 is on a distinguished road
Default help-buying 97 blazer with a dead engine
I'm probably buying a 97 blazer from a coworker he say his engine just died out and I have a spot to buy a complete engine but its out of a 2002 is it the same type of engine?
Old Jul 9, 2012 | 08:45 PM
jaked up's Avatar
jaked up is on a distinguished road
puting a 02 motor in a 97 will not match up to the trans
Old Jul 10, 2012 | 09:34 AM
What's the difference
Old Jul 10, 2012 | 10:12 AM
Well, what jaked up posted isn't 100% accurate. The engine & trans will bolt up together just fine. It's the dust cover that might not work quite right if your trans has one. The '02 motor will have an aluminum oil pan, but that doesn't mean you can't swap the pan from your '97 motor if yours is steel. If you have an aluminum pan, it's a direct swap.
There are other differences though. The '02 engine will likely have a two wire knock sensor that bolts onto the back of the bell housing instead of threading on. The block will have to be drilled & tapped for the 1/4" NPT threads required for the older knock sensor. Also, the lower intake manifold may not have provisions for the EGR valve or the coolant temp sensor in which case, you will need to swap your lower intake manifold over onto the replacement engine. In that process, keep the injection spider as it will be the upgraded MFI spider.
Dallas1970
Feb 22, 2019 05:05 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
djboyzs
Oct 14, 2013 07:14 PM
rfine67
Aug 13, 2011 01:04 PM
ricky
Jul 22, 2010 08:04 PM
