97 wont engage until warm.
Old Sep 17, 2011 | 07:39 PM
sir loin's Avatar
sir loin is on a distinguished road
Default 97 wont engage until warm.
Here's the newest issue I'm having with my blazer. The trans won't engage ( or wants to and then slips) within the first 10 mins of starting it. After it warms up its fine. I want to check my trans fluid but the dipstick is really stuck. It's crimped shut right at the top where the tube first begins. Ive been searching for a post I read a while ago that was similar, but can't find it. Can anyone help?
Old Sep 17, 2011 | 07:51 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
What exactly do you mean crimped? Could you squeeze it the opposite way to uncrimp it? this could be one of those things where if you add more fluid to the tranny, it will remedy the problem.
Just a thought
Old Sep 17, 2011 | 09:14 PM
sir loin's Avatar
Well not crimped,..... damaged. It kinda looks like a half moon. I was thinking of taking channel locks to it, but don't want to risk causing more of a problem. If this sound like it could be a fluid issue then ill concentrate on getting the stick out.
Old Sep 18, 2011 | 02:04 PM
It could be something as simple as the fluid level, but without knowing the level, ya never know
Old Sep 21, 2011 | 12:39 PM
sir loin's Avatar
I can not get my trans. dip stick out. I''m pulling so hard I think I may break something. Any suggestions?
Old Sep 21, 2011 | 01:16 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Yea try to un crimp it just be carefull not to crack the dip stick . The dip stick tube is pretty easy part to fix theres only one bolt on the transmission bell housing then pull it out and slide the new one in . Make sure the tube gasket is in good shape to or it will leak .
Old Sep 22, 2011 | 09:17 PM
sir loin's Avatar
Replacing the dipstick tube will be my next step. Thanks for the info.
rtreftz
Jul 10, 2014 03:37 PM
syriusly
Feb 23, 2013 07:04 AM
tim68
Jan 11, 2011 10:30 PM
hitechracing
Sep 1, 2009 11:52 AM
myetman
Aug 29, 2006 05:00 PM
