97with.shifting.issue.The.PO.saysit.slips.whenc.ol d
Old Aug 11, 2018 | 07:13 PM
DARK1's Avatar
DARK1 is on a distinguished road
Default 97with.shifting.issue.The.PO.saysit.slips.whenc.ol d
The.Exhast.has.been.cut.(really.loud).The.Tranny.s lips.between.2nd.and.third..If.you..back.off.the.t hrottle.it.usually.slips.into3rd.fine.Hes.a.mechan ic.andswears.It.just.needs..a..$78.Sensor.mountedo n.top.of.Tranny.he.has.to.get.rid.of..it.and,now.o nly.wants.$400
His.images.were.shot.in.the.dark.and.a.Night.showi ng.of.the.test.drive
Old Aug 11, 2018 | 07:57 PM
rriddle3's Avatar
What.kind.of.punctuation.typing.is.that
Old Aug 12, 2018 | 12:32 PM
Transman304's Avatar
Thumbs up
Might be able to help but can’t understand question.
Old Aug 12, 2018 | 12:48 PM
I recently discovered that when posting from my phone to FB, if I add two spaces behind a word, it will assume it is the end of sentence and then insert a period. Gotta find out how to stop that. Maybe that is what is going on here.
Old Aug 13, 2018 | 09:53 AM
DARK1's Avatar
.punctuation.typing...is.a.temporary.workaround.fo r.a.broken.space.bar
Old Aug 13, 2018 | 10:39 AM
DARK1's Avatar
Also,the.4wd.buttons.are.unresponsive.
4WHi.is.lit.but.I.cannot.put.it.in.2WD
PO.said.the.actuator.was.bad.and.4WD.did.not.work
Old Aug 13, 2018 | 12:08 PM
When the 4wd system is not engaging it is worth checking to see if the transfer case control module (TCCM) has gone bad or has a bad connection. It lives behind the passenger side kick-panel so is easy to check. Look for threads on this and for videos online to describe the symptoms of a working versus non-working module and how to check the connector.
959900s10blazer
Shows & Clubs
Jan 31, 2019 01:08 PM
AlwaysWanted1
Feb 25, 2018 10:22 PM
loganreeves
Performance & Brainstorming
Mar 30, 2009 10:13 AM
EuroGoldLS
Detailing
Jun 5, 2007 01:07 AM
