98 4.3 swap into 97
Old Aug 2, 2016 | 10:32 PM
JBood's Avatar
JBood is on a distinguished road
Default 98 4.3 swap into 97
Found a running 1998 4.3 to swap into my 1997 2 door 5 spd. Both are vin W but the 1998 donor is an auto 4 door. From my understanding it's a direct swap just use the computer from the 5 spd. Is this correct? Anything else I should know? I've got a lot of new parts on the '97, true duals & hi-flow cats, CAI blah blah blah. Gonna do the clutch too while its out obviously. Am I missing anything?
Old Aug 3, 2016 | 08:56 AM
LesMyer's Avatar
don't forget to install the pilot bearing in the new crankshaft.
Be safer to use the intake and exhaust manifolds from your 1997 (you should really do lower intake gaskets anyway). Then you should be able to be assured that all your 1997 stuff fits and works as designed without mods.
Old Aug 3, 2016 | 02:18 PM
JBood's Avatar
thanks Les, I've never done an engine swap but I have some very experienced help lined up. I plan on replacing most of the gaskets (as you suggested) and eventually rebuilding the one I'm pulling. Found the '98 for $250 (it's a 4 door with a toasted auto trans). Heard it start/run yesterday, no engine noise, no smoke.. I figure I can get at least $100 out of the rims on it alone...
Old Aug 4, 2016 | 09:55 AM
LesMyer's Avatar
Good luck and best wishes!
poepoe624
Jan 10, 2010 11:48 AM
Boiler_81
Dec 2, 2008 10:04 AM
95_4door
Apr 8, 2008 01:31 PM
Shade
May 13, 2007 05:54 PM
Talusgirl
Sep 23, 2005 03:58 AM
